Search the forum,
Discuss Patio heater (hard wire) in the UK Electrical Forum area at ElectriciansForums.net
hadley1
Hi all,
I am looking to install a 3kw patio heater spurring off an existing socket (on a ring main) as below:
1. Cable to isolator switch (32 Amp TP&N Rotary Switch Insulated Weatherproof - IP65 | Contactum (DX032AC) - https://www.tlc-direct.co.uk/Products/CMDX032.html)
2. Cable from isolator switch to 16A push switch (16 Amp Time Delay Touch Timer - IP66 | Elkay (560A-1) - https://www.tlc-direct.co.uk/Products/EK560Adash1.html)
3. Cable from 16A switch into patio heater.
Cable will be 1.5mm2 SWA.
Is this proposal OK?
Thanks.
It would mean a lot of builder's work to put on a new circuit. The current circuit is on a 20A MCB which feeds two double sockets, neither of which are in use.
Hi all,
Thanks.
No general advice is any load of 2KW or over needs to be on it's own circuit spurring from an RFC is not advisable, 1.5MM2 is hardly large enough for the 3KW heater load
Yes potentially but it would render the project unfeasible hence why I ask the cable size as I imagine the cost of an electrician will be considerably less if they simply do the terminations.
only 2 sockets on a 20A? So is this a radial circuit, and not an RFC as you believe?
If its a radial, then I would say its fine to add this load... its protected by 20A... Is there an RCD for this circuit?
I would use 2.5mm SWA, however, as it will be the same size as the supply cable to the sockets.
The Spark as you call him.her will need to size the cable and OCPD and test the installation on completion so it's not just termination that's involved Mate, could be a problem getting someone to do this work if they weren't involved in the complete install, just saying, not just a case of lashing in the cable either length of run and installation method need to be accounted for.
Reply to Patio heater (hard wire) in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I've recently moved into a house and would like to check please whether an immersion heater that looks recently fitted has been correctly wired...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
I want to power a small heater 2kw in my bedroom with this wireless thermostat. Because its affordable and has very fine 0.25C heat sensing...
