Currently reading:
Please Help, wiring a switch with a singular 3 core wire
Discuss Please Help, wiring a switch with a singular 3 core wire in the DIY Electrical Advice area at ElectriciansForums.net
lucasgill
Hi, im having trouble. I want to wire up some outdoor lights through a smart home plug. They were previously connected to an analouge timer and after removing this ive found that there is one singular wire coming from the lights. this wire has neutral (blue) live (brown) and another black wire which im struggeling to identify. ive attatched images of how they were previously wired into a time guard timer. Idealy i want to wire it so that i had a an outlet which i could plug the lights into through a smart home switch. Apologies in advanced as this is probably a stupid question however any help would be thoroughly appriciated :)IMG_20200526_171414.jpg
You should not be putting a socket on that circuit.
If you want the lights to be controlled by a smart switch, you should buy a smart light switch, not a socket.
The black is the switched live to the lights. It should have brown sleeving or tape to identify it as a live conductor.
Reply to Please Help, wiring a switch with a singular 3 core wire in the DIY Electrical Advice area at ElectriciansForums.net
