- Reaction score
- 7,771
There is a small cu in that pic you sentThere is an Earth Bar in another mains room, approx. 20m away next to the Ryefield Board that supplies each of these meters
So the cpc must go in that back to the earth bar.
Discuss PME Supply Advice in the UK Electrical Forum area at ElectriciansForums.net
No, the only cables entering this are L+N from the henley. I can only assume they have linked internally within the CUThere is a small cu in that pic you sent
The Ryefield Board is in another room yes, there is a small cu next to the cut out.No, the only cables entering this are L+N from the henley. I can only assume they have linked internally within the CU
Please forgive my crude attempt lolThe Ryefield Board is in another room yes, there is a small cu next to the cut out.
Put a diagram on here so that we can work it out.
Bloody hell did a kid do that drawing or are you drunk. LolPlease forgive my crude attempt lol
That small CU next on the adjacent fuse must have linked N+E within the CU as there are only the L+N tails entering and SWA leaving
Both lolBloody hell did a kid do that drawing or are you drunk. Lol
CU in, earth's back to the Ads. That probably needs doing.
That's going to cost some pennys.
What with the drunk drawing or drunk kidThanks for the advice, client will be chuffed lol
Just reading some regs and need to make sure I am not misinterpreting it. If a ran an earth back to the earth bar by the Ryefield board, would I not be contradicting 543.4.3? And in that case would I link CPC to Neutral at the Henley block in the mains room (as it seems other have done) as to not contradict it?What with the drunk drawing or drunk kid
Doing it.
Reply to PME Supply Advice in the UK Electrical Forum area at ElectriciansForums.net
