Search the forum,
Discuss Proteus 3 phase DB horizontal in the UK Electrical Forum area at ElectriciansForums.net
Seen pictures of it, looked promising but - its Proteus!
I know they do both "consumer" 6kA RCBOs and "commercial" 10kA ones but never compared them or checked for compatibility lists for their boards, etc.
Just looked and they say "Units will accept 6kA and 10kA MCBs and DIN Rail mounting HRC fuse carriers" which is promising, though checking CEF site I don't see any fuse carriers. Shame as there are times a fuse for a sub-main would be perfect!
Not a lot of room at the top of the DB for dressing in neutrals and cpcs. Used to Hager myself, first time fitting a proteus
It looks like Proteus is the only brand offering "Type A" single-row TPN boards. So if space limited then its your only choice!
EDIT: I think they do a 10kA "compact" RCBO as well.
Used a few of these on EV installs They are not the best but good for small spaces not had any issues as in call backs either.
I used to make up type A boards using Hager enclosures and devices but Hager will give no warranty on home made boards even with their own parts,so w,ere stuck with Proteus..
Reply to Proteus 3 phase DB horizontal in the UK Electrical Forum area at ElectriciansForums.net
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion. My particular...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
A friend of mine got a 2nd hand coffee machine (OK, probably 3rd or 4th...) for use in a charity cafe and it has problems. First problem is no...
