Discuss Proving units maximum voltage in the UK Electrical Forum area at ElectriciansForums.net
I decided,having lived with using a live circuit, to buy a proving unit. I opted for a Kewtech Prove 4 which covers 5 voltages between 690volts and 50 volts. The device starts at 690 volts which is ok for my Megger 2 pole tester. My fluke clamp meter has a limit of 600 volts. The second problem is that the unit spends only seconds in the low voltage ranges and it’s too fast to check the readings easily in these ranges.
Has anyone used this device with testers that have lower limits than the 690 volts ?
I think what he means is that the kewtech unit outputs 690V initially, which is above the maximum limit of his Megger voltage tester.
The Kewtech one starts off at 690V and if you hold the probes in it will step the voltage down every second or two. This is to do a full test of the kewtech voltage probe, so that you can confirm each voltage range is working OK
My fluke clamp meter says don’t use if voltages greater than 600volts - and the kewtech starts at 690 volts and you can’t say “please start lower than 690 volts.
If the proving unit had started at the low end (50volts) and slowly rise to the higher voltages where you could halt before going to higher voltages by removing the probes surely would have been safer ?
I think suitable devices have been given in post 4 by nicebutdim.
Reply to Proving units maximum voltage in the UK Electrical Forum area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hello, I have a EV charger that is reporting over voltage and is unable to charge. the charger will operate up to 253V The solar inverter reports...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I will start by apologising to @westward10 as he will have had to take time out to move this thread to the correct section. I am terrible at...
6K
