Discuss RCBO indicator , short circuit or earth fault. in the UK Electrical Forum area at ElectriciansForums.net
Not RCBOs, but Hager AFDDs - which include an RCBO - indicate why it has tripped:
"The multicoloured LED display will flash in a different sequence of colours to identify the fault. With the ability to identify 8 statuses, the device will instantly detect if a Series Arc, Parallel Arc, Overvoltage, Residual Current Fault, Overload, Short Circuit, AFDD failure or manual trip has occurred, saving time and improving diagnostic ability."
You can also download a fault log showing the last so many trips (8 or 16, I think) from the AFDD via Bluetooth.
Having said that, I know there have been some concerns raised about Hager AFDD reliability.
Hager RCBO's have a green indicator if the trip was caused by an earth fault, if it's just tripped without the green indicator then its an imbalance or overload.
As I am retired, the Hager AFDD's would be redundant in my property, the only one I work on now days, I have an all RCBO board and it just sits there getting on with the job.
Reply to RCBO indicator , short circuit or earth fault. in the UK Electrical Forum area at ElectriciansForums.net
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi all, Gone to look at a intermittent ground floor sockets fault today, the RCBO was tripping at random times with no pattern. Nailed down a...
