Search the forum,
Discuss Recessed LED lights glow while off, but only when laptop is charging in the DIY Electrical Advice area at ElectriciansForums.net
benwa100
I am mostly curious as I don't think this is a very important issue.
In my bedroom I have 2 overhead recessed LED lights that are not on a dimmer. After several years of living with no issue, last week I noticed that they remained faintly on after turning the light switch off. They glowed faintly and persisted for at least 1 hour. After some investigating, I found that if I unplug my laptop that charges at a nearby outlet, the glowing stops immediately. If I plug the laptop back in, the glowing comes right back. The outlet is in between the light switch and the overhead LED lights, but the outlet is not on a switch.
Any ideas as to what is going on? I have tried plugging in some other devices to the same outlet and it doesn't make the LEDs glow. Is the laptop battery somehow powering the LEDs?
Thanks!
TL;DR
Recessed LED lights glow while off, but only when laptop is charging in nearby outlet.
Thanks!
The first thing that comes to mind is you possibly have your switch going bad. Try changing your switch and see if that helps.
Do you mean replace the switch that controls the lights or the outlet where I plug in the laptop? To the best of my knowledge, they are totally separate from each other. I find it really bizarre that the ceiling lights only glow when I plug in a laptop to the separate outlet.
Change the switch and yes it is bizarre and your switch could be acting like a triac which leaks voltage even when off
Reply to Recessed LED lights glow while off, but only when laptop is charging in the DIY Electrical Advice area at ElectriciansForums.net
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
