Discuss Regular blowing of 13a fuse. in the UK Electrical Forum area at ElectriciansForums.net
Luke1979
Hello
I’m a floor fitter looking for a bit of advice.
I’ve recently bought a floor grinding machine that has a standard 13a plug. When the machine is up and running, it runs at around 2kw. My problem is when I first fire it up, the motor quickly draws a load more power and regularly blows the 13a fuse.
Any suggestions for how I can overcome this regular blowing of fuses?
TIA Luke
Having done some work on this type machine I'm sure these need to be started and allowed to get up to speed without the grinding discs in contact with the floor
Reply to Regular blowing of 13a fuse. in the UK Electrical Forum area at ElectriciansForums.net
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
  • Locked
I read once, never seen one for sale, that there is a solid brass replacement for the standard 13A fuse in a 13A plug. This is to eliminate the...
12K
  • Locked
5K
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
Hi all I’m new here so hello and thanks for looking. I’m looking for what is, I’m hoping, a quick bit of advice. I’m having an 8kW sauna heater...
