Discuss Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
Taylortwocities
Supporter
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side.
There's no way to replace the meter tails. Is there another manufacturer that has a left-hand main switch CU, or a flexible position option?
Thanks muchly!
Thanks muchly!
I would use Fusebox with rcbo's.
I try and stick with same make as one of my peeves is having a box full of various make mcbs/rcbos etc taking up space in the van all it does is seem to grow.
Fusebox populated spd sp+n rcbo boards are decent for the price.
I always keep my eye out on flea bay for unused rcbos etc as I’ve had some good deals.
I don't recall seeing Fusebox being configured with a left hand main switch??
Reply to Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
