Currently reading:
Rough cost of big job help needed ??
Discuss Rough cost of big job help needed ?? in the UK Electrical Forum area at ElectriciansForums.net
Dl1977
had a quote on this job not sure if it's decent price any help needed ???
Lounge
4 x double socket
1 x single socket above fire for TV
1 x television aerial point and wiring to booster position
2 x HDMI cables from TV to corner
2 x 5amp sockets switched from door
1 x picture light and switch
2 x wall light and switch
1 x centre light and switch (dimmer)
Dining
3 x double socket
Hall
1 x single socket
1 x 240v smoke detector with 10year lithium cell and interconnection
1 x under stairs light position and switch
Rear Entrance/Porch
4 x LED spotlight and switch
1 x double socket
WC
2 x LED spotlight and switch
1 x extract fan with timer, fuse protection and isolation switch
Utility
2 x double socket above worktop
2 x sockets within units for appliances
1 x extract fan and switched spur for control
Kitchen
3 x double socket above worktop
1 x socket above units for cooker hood
1 x 30amp supply for induction hob, complete with local isolation switch
1 x 30amp supply for double oven, complete with local isolation switch
8 x LED spotlight and switch
1 x switched supply to under unit lighting, including connect fittings supplied by others
1 x switched supply to plinth lighting, including connect fittings supplied by others
Rear Living Room
3 x double socket
8 x LED spotlight controlled via 2 switches
Terrace
1 x external socket
Landing
1 x double socket
Master Bedroom
4 x double socket
1 x single socket for TV
2 x wall light positions above bed and switches
Dressing Room
1 x double socket
3 x LED lights within wardrobes, controlled by door switches
En-Suite
3 x LED spotlight and switch
1 x mirror supply, including installation of mirror supplied by others
1 x switched spur to supply under floor heating, including supply of matt and programmer along with connection
Front Bedroom
4 x double socket
Rear Bedroom
3 x double socket
Bathroom
External
1 x switched supply to 2 x LED up/down LED light fittings, 1 either side of front door
1 x switched supply to 2 x LED up/down LED light fittings, 1 either side of terrace door
1 x motion controlled LED floodlight to rear entrance
1 x motion controlled LED floodlight to drive
Further Works
1 x main RCD/MCB distribution board to be positioned within utility room
1 x main earth bonding to water and gas/oil incoming positions
‘Granny Flat’
1 x armoured supply from house DB to new distribution board
Lounge
3 x double socket
Office
3 x double socket
1 x telephone and data point
Stairs
1 x centre light and 2way switching
Landing
1 x double socket
Bathroom
Bedroom
4 x double socket
6 x LED spotlight and switch
External
1 x armoured cable to weatherproof socket for water feature
1 x armoured cable, switched from main house, to supply future garden lighting
1 x LED floodlight with motion control and over-ride
Intruder Alarm
1 x main control panel with battery back up
2 x keypad
2 x external bell box with sirens and strobe light
9 x motion sensor
1 x door sensor to front door
If it was me I would give the Job to the 10k man. Other is too cheap and is likely to cause a problem somewhere along the way. Sit down with him and ensure he has included for everything though cause it still seems a bit on the low side
Edit: even get a 3rd and 4th quote... where in the country are you?
I'd go with @telectrix £12k minimum, and 15k worst scenario. I really can't imagine someone could do a decent job and get a profit out of that at £8750, £10.5k is very close to the bone, I imagine you will be getting the cheapest cable and fittings going at those prices.
Reply to Rough cost of big job help needed ?? in the UK Electrical Forum area at ElectriciansForums.net
