J
John Matrix
Hi everyone I have an issue that I need some advice with. I have been asked to fit a panel board in a basement to some offices. From this I need to feed another distribution board. This board is feeding some general lighting and power. My plan was to link everything with a 100x100mm metal trunking and then run tails through the trunking from the panel board to feed the distribution board. I have been told that I should be keeping the tails and the general lighting and power circuits in separate trunking but I can’t see an issue with running it in the same one. Is this ok or do I have to run it separate?
