Search the forum,
Discuss Scantronic ion 16. Super fail v9 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
den123
Hi all can anyone help please can’t set alarm says on Pannel Super fail have changed main battery in control panel also in pir. Still the same any help please guys
is this an auto correct issue?
Super fail, Did you mean Supply fail??
if so then look to see if a fuse or circuit breaker has tripped.
Reply to Scantronic ion 16. Super fail v9 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hello there I have just installed a new Solis S6-GR1P3.6K-M-DC Inverter - this replaced a 10 year old+ Sungrow inverter that failed/out of...
Hi I have a scantronic 9800 control panel with Aritech sensors. One of the window shock sensors has a continual red led lit. The system is around...
