Discuss Self test emergency in the USA Electrical Forum area at ElectriciansForums.net
Is this three separate units?
Yes,the idea is to test the battery duration first unit failed ,second unit also failed and passed in third unit.To confirm it again I tested a different battery on the first two unit that failed too.What may be the cause it doesn't meet the duration?
Yes three different units of same circuit design.First ans second failed duration at 150 mins as rated duration is 180,But the third one passed.First two also failed while trying with different battery.What cause that to happen?Please
If three separate units and you have tried different batteries then the faulty units are probably draining to much current.
Are the floro or LED.
I have replaced a few hundred old units over the last few years at work and we are now all LED.
We have dramatically reduced our fail rate.
Thanks for your kind reply.They are LED and gears are quite new design .We will test the units to sort it out.Thanks again
Could also be the battery you swapped were also duff.
I have had very few LED units fail.
Out of a few hundred maybe a handful have had to be replaced
Reply to Self test emergency in the USA Electrical Forum area at ElectriciansForums.net
Hi, RCBO appropriate test facility for emergency lighting? I have a car storage facility ( one corridor with 10 rooms off the corridor to store...
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician State Laws for Electrics and Electricals may differ on a state-by-state basis. American questions and answers can be found in our UK electrical forum.
