Discuss Shared income supply main fuse in the UK Electrical Forum area at ElectriciansForums.net
Hello, my incoming supply has one main fuse that feeds the next door naghbour it leaves my house to go next door as shown in picture..it's the single cables going through the hoteCan this be split, and how would be responsible for any changes.Thanks
Paul
Are you an electrician?
Looped (shared) supplies are not uncommon although your cutout is not one that I recognise.
From the photo it is impossible to tell whether the feed to next door is taken from the supply side of the fuse and then fused next door or if it is taken from the load side. Whichever, for any changes you would need to consult your electrician who will probably refer this to the dno
No I'm a maintenance Technician,
Its the two single core VIR cables coming off the load side going though to the next door neighbours house do know how its routed .
Sorry don't know what dno means
Thinking that separate fuse would be a better option ,. Not long moved in,
Ifs its the energy network you mean its Scottish power
Thanks for the response
Distribution Network Operator
Reply to Shared income supply main fuse in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi all, any recommendations for neat and complaint ways to "house" a new supply -- the main electrical fuse, cut out, meter etc that on our house...
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
