OP
Knobhead
Picture 9, is that a dual bus-bar sytem?
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
Couple of observations;
- The layout of the conduit should have been considered so that they did not need to cross
- Conductor length needs attention, if you look at one of the browns in the spur you can see where it has been rubbed when the faceplate screwed back.
I appreciate a lot comes with experience, but it's things like the scuffed cable that can cause you problems both in college and the real world, I would be none to impressed when testing a new install to find that.
From what I remember, they must cross as part of the assessment, and a large portion of the marks are dependent on your ability to set the conduit neatly
I would be asking, why you have pulled CPC's into a galvanised conduit system in the first place?? All your achieving there, is filling up the conduit with needless copper!! lol!
Then they are all bloody idiots!! ''Just in Case'' has no relevance in electrical design concepts!!
but would argue (forgetting relevant Laws/Guidance) that a very high percentage of design is for "just in case" scenarios. Fire Alarms, Intruder Alarms, Controls, Cut-outs, E-stops, UPS, back up Generators, less abled alarms, could all be placed in the "just in case" bracket.
Started new job today....lots of trunking, tray, conduit, basket, skirting trunking,dado, ect ect ect .
and I have to fit all this in a 100mm space above a suspend ceiling!
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
