Search the forum,
Discuss Signal strength on freesat in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hello, I've recently been having problems with my freesat set up. I have two freesat boxes connected to the same satellite dish, some channels are weak or missing but not necessarily the same on both boxes. I've checked the cable connections both ends and that the dish hasn't moved, and thoughts?
it sounds like the dish has moved, if both are experiencing problems.
The differences between them may be down to the age of them, or electronics inside. Some tuners are just better than others.
do you have a satellite signal strength meter, or are you just using the inbuilt one in the set top box?
Maybe not the dish itself, but the LNB on the end of the arm has moved?
I've been using the inbuilt meter but I do have strength meter, the dish is a bit rusty could this be the problem?
Reply to Signal strength on freesat in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
I have unexplained equipment and diagram for three separate connected f81 connectors. Each f81 connector is connected to single receiver to single...
Hi everyone, I'm a newbie to the forum, and I'm hoping my question won't be too stupid. I'm in NYC (Manhattan), and have an apartment where a...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
