Discuss Sockets in a public place inside locked steel cabinet in the UK Electrical Forum area at ElectriciansForums.net
mattg4321
Been asked to supply 13a sockets to 2 positions round a sports facility. The expected load is small, but the length of cable run is fairly long. I’ll probably be using 10mm2 2core with the swa as cpc.
They have had problems with kids etc gaining access after hours and fiddling with things etc so I was thinking of locating the sockets inside a lockable steel enclosure (any recommendations on brands to use/avoid?). I was then thinking that these things may get used in the rain, so do I price for IP66 sockets and accept the enclosure door will be left open? Or do I go for plastic/metal clad and find some way to shut the enclosure/cabinet door on the lead/drill a big hole in it.
Also given there are 2 points on the circuit, each with 2 sockets, how do I terminate the 10mm2 into the sockets. Maybe I could step it down to 2.5mm2 in a steel adaptable box inside the enclosure that I would gland the cables into? What to use to make the connection between 10mm2 and 2.5mm2.
I’m sure someone will come up with a good idea, I feel like I’m going round in circles here. Think having a 6 month old is catching up with me!
Use din rail connectors to reduce the size of the cable.
You could fit an isolator internally in a suitable location so that the sockets can be isolated when not in use to prevent unauthorised use.
I'd use a GRP enclosure rather than steel if possible as they don't rust, steel enclosures need to have any damage to the paint fixed regularly or else they will rust.
Most wholesalers will have a range of suitable enclosures with hinged doors and mounting plates on the shelf with standard 'rittal' key camlocks, or you could pay a premium and get genuine Rittal enclosures.
Reply to Sockets in a public place inside locked steel cabinet in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
  • Locked
5K
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
I thought I took a photo earlier but seemingly not. Someone's fitted a joint box to move a consumer unit. It's a refreshingly neat job. Din rail...
