Discuss Spurring off FCU supply side in the DIY Electrical Advice area at ElectriciansForums.net
wassupjg
Hi, apologies for the basic question
In a radial circuit, is it permissable to spur off the supply side of an existing fused connection unit?
https://community.NoLinkingToThis/attachments/upload_2024-2-20_23-51-27-png.97495/?temp_hash=48457ecb731469aa9c115336390af84f
As above, 3A FCU is feeding a floodlight, is it okay to spur off the supply side of the 3A FCU to feed a 13A FCU, isolating an outdoor socket?
Cheers
Reply to Spurring off FCU supply side in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
I found a 13A FCU, connected to the kitchen ring supplying an outdoor junction box, providing two SWA 2.5mm radials. Unconventional? yes. One...
