Discuss Steel Channelling vs PVC Channelling in the UK Electrical Forum area at ElectriciansForums.net
Neither, personally I prefer to use 0val tube. Looks neater and you can easily pull through it.
Just curious why heavy gauge? I'd use 20mm light gauge, tracked in.I put normal pvc heavy gauge 20mm conduit in tracked walls
It would depend if it was across the sub floor and up the wall, rather than down the wall.Just curious why heavy gauge? I'd use 20mm light gauge, tracked in.
Reply to Steel Channelling vs PVC Channelling in the UK Electrical Forum area at ElectriciansForums.net
