Discuss Thermal overload in the UK Electrical Forum area at ElectriciansForums.net
Well, we can say: YES. If you overload your cable, it can melt, and if there is something very dry, it will burns.Can a thermal overload protect against fire?
Motor thermal overloadsDo you mean a thermal-only breaker for over-current, or a heat-sensitive fuse?
They're to protect the motor windings.Motor thermal overloads
You could, but it's only for protecting the motor.So does the thermal overload protect the motor cable? For example if I had a circuit feeding a large motor originally then had to connect a temporary bit of equipment of the same circuit which was a smaller motor could I just reduce the overload on that starter?
Reply to Thermal overload in the UK Electrical Forum area at ElectriciansForums.net
