Discuss Training to be a sparky in the UK Electrical Forum area at ElectriciansForums.net
hi guys, I'm having trouble understanding a question in my course book.
Q. "State the current ratings of the following ring final circuit components and accessories."
1. circuit protective device -
2. socket outlet -
3. fused connection unit -
Reply to Training to be a sparky in the UK Electrical Forum area at ElectriciansForums.net
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, I'm doing my Level 3 Electrical Install course, and I'm doing distance learning so most of the work is being done by myself with no guidance...
