Search the forum,
Discuss Under cabinet led strip lighting connected to light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have replaced some under cabinet kitchen tube lamps with LED ones. I followed the same layout and just replaced the lights. Each light (4 in total) is wired to its own fuse box and operated by the kitchen light switch on the wall. As well as each light being connected to a fuse box there is also a wire that connects between the 1st and 2nd fuse box. Without this wire (I removed it because we had kitchen cabinets changed) when the light is switched on only the 1st light illuminates. It seems this wire allows all the lights to come on. I was wondering, given that the LED lights can be connected together (they have a male connector one end and female on other) is there another way to get all the lights to come on without this additional wire? Many thanks
Reply to Under cabinet led strip lighting connected to light switch in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi All, I am currently in the process of building an extension and I need to purchase some led downlights for my kitchen but unsure how many I...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
