Currently reading:
Very high r1+r2 readings and Zs in conduit?
Discuss Very high r1+r2 readings and Zs in conduit? in the UK Electrical Forum area at ElectriciansForums.net
K
Kev2632
Hi,
Why would I be getting very high r1r2 readings and Zs readings in a water heater circuit wired in the existing conduit when the house was built back in 19oatcake...? Would the conduit have anything to do with it and if so? Why?
All my other circuits readings was good, tn-s system, all connections are tight, and disconnected the water heater supply side from the switch and was still getting weird readings??
Yea that's what I'm thinking too, yea I elminated the switch from the circuit so I only had my live coming in from the consumer unit, and tested to the earth on the backpack where the conduit came in, you know?
with the CSA of the conduit in which its wired, will that allow it too have such a high reading? or would that normally give a very low reading if the conduit is " sound", because the CSA area is bigger so it should in theory have alot lower reading than the R1+R2 of live to earth in twin and earth yea??
Is the conduit earthed correctly at the consumer unit? Does the consumer unit connect into the conduit? is the consumer unit plastic by any chance? Are all the other circuits earthed using the same wiring method?
we are all sat at home in front of keyboards with a beer cos nothing is on TV.
We need the maximum amount of info if we are to help.
AND, when you do get it sorted, come back on here and tell us what the problem was so we can all learn!
Reply to Very high r1+r2 readings and Zs in conduit? in the UK Electrical Forum area at ElectriciansForums.net
