Search the forum,
Discuss What is my oven element doing? please in the Electrical Appliances Forum area at ElectriciansForums.net
Sammyrose
I noticed yesterday the element has starting bending down why is this happening and is it still safe to use until it can be replaced in a few weeks?
Thank you
'Safe' might be a relative term - I'd certainly suggest that it's going to fail very soon and stop working, if you're lucky it'll fail 'open' and just stop getting hot, unlucky and you'll have a brief pop and get to find out if your protective devices are doing their thing properly.
Cooker elements are not expensive (£20-30ish?) and take a few minutes to swap over for someone competent, please don't put this off longer than you need to.
Thank you I didnt think it would last long I've gone onto parts master and found an element that is listed for the model I have £36, would you know why it has bent like that I've not had it happen before to any ovens.
It can happen when the element is about to fail but it could also be caused by a thermostat that is failing and has caused overheating of the element
Right ok that's not good, hopefully replacing the element will sort it out for a while I've only had this oven about 4yrs, I'm guessing it's still ok to use the hob so can still make some meals while I wait to fix it, Would you say that it's still ok to use the hob? Many thanks
I'd have thought so. By the way, if you get massively stuck with this and need a hand then I'm TA10 (just seen your profile), drop me a message on here if you need to.
Ok I thought that hob might alright to still use as I assume that the elements aren't connected cos I dunno if I can live on micro meals, thank you I'll remember that
Reply to What is my oven element doing? please in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, as the title says, I need to change the upper heating element on my HE10AB220/C oven. I've never done that and it seems pretty easy, as in...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hi, To give a bit of background, it is a Lincat ESLR9 electric cooker. It is very simple design with two fans and two elements. Two weeks ago...
