Search the forum,
Discuss Would T&E be approved for use in steel conduit and outdoors? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, My first post so hopefully I am correct in posting it here.
My question is, I am thinking of an IP rated outdoor socket for the back garden.
I have drilled out to the exterior and now wish to move the socket 1 meter away from where the hole is.
I would say use of steel conduit would be best for this application but what cable type would you use in the 20mm galvanised conduit?
OSG doesn't recognise T&E being used in Conduit, and I don't believe singles would be suitable for use passing through bricks without mechanical protection of the sleeving.
Kind Regards and Thanks for your help everyone
It’s fine.. bit awkward to install in conduit especially LSOH 2.5mm T&E
Reply to Would T&E be approved for use in steel conduit and outdoors? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am going to need to install a small amount of galvanised steel conduit, leading down to perhaps 4 sockets and a light switch. This is in a...
4K
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
I have a TPN board that will feed 8-10 sub boards. The loads on each board are negligible 5-10 amps peak but mostly 1-2 amps. The distribution...
