Discuss WS2812B led strips, Series or parallel? in the Lighting Forum area at ElectriciansForums.net
I have tried to find info on connecting WS2812B led strips Dat/signal line without any luck. I wondered if it was ok to connect the dat/signal line in parallel to 2 existing led strips from the controller or does it have to be in series?
Reply to WS2812B led strips, Series or parallel? in the Lighting Forum area at ElectriciansForums.net
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
