Guest viewing is limited
Offshore Information Sheet No. 1/2011
It's all covered in there, as is what I was saying about competence.
I don't have time to type out a long winded answer as I'm just about to knock off my dinner break.
Ha, so you don't have time to type "DETAILED INSPECTION" but you do have time to post up a HSE link.
Theres 3 checks to do;
1,visual
2,close
3, detailed
but this you know!
As i've said you can use anyone you want to install it but you wouldn't use a 9 year old bloody school girl, of course you use someone who can do the job unless your training someone. The point i'm making its up to you who you use but a compex trained person should check it
So you would deem them competent then?
I personally wouldn't ever sign off an Ex installation by just doing a visual and the odd initial.
As your not a qualified ATEX inspector or compex qualified (i know this from your replies), you're not allowed to sign off someone else's work.
1,visual
2,close
3, detailed
but this you know!
I would disagree, Why is that 99.9% of the oil and gas industry only employ/use compex qualified workers??
And this also includes instrumentation techs as well as electricians?
Your right I'm not compex qualified. If you think that's the be all end all in signing off Ex work, I think you need to do some reading up.
I've never seen one either apart from the one in his photo. It looks like a decent product so I'm assuming there's some mysterious logic or maybe some new reg I'm not aware of behind the arrangement or only being able to remove covers in the on position.
Oldham
ATEX Isolator front removal?
jinjoh_ninjoh,
jinjoh_ninjoh,
