A new extension requires a new TPN mcb dis board and I was looking at serving it from the existing MCCB panel board but breakers for it are obsolete and there aren't any breakers that can be retrofitted into the board.
Who would:
1) suggest the whole MCCB panel board is upgraded and serve the extension DB from the new panel board
Or
2) split the tails after the meter and fit some Lucy blocks; serve a new switch fuse unit and serve the extension DB from the switch fuse. And keep the existing MCCB panel board well alone.
Your thoughts would be much appreciated?
I have just tried to find it however since i last looked the esc have just redone the website, now it seems more aimed at consumers rather than the electrician
i have found
IEE Guidance Note 2 - "Isolation & Switching", p.40
"It is permitted for an installation to have more than one electrical installation. Therefore one 'main switch' is not required to isolate all consumer units simultaneously provided the consumer units have an integral main switch.
does consumer unit extend to TPN mccb panel boards too?
No, they are distribution boards.
No they don't. I need something that is backed by manufacturerd warranty. I'm reluctant to firing something that has been stored at the back of a shelf for circa 15 years hence why I don't want to go down the eBay route.
Their are companies out there that sell reconditioned equipment like panel gear MCCB's, they come with a guarantee too.. I have used these in the past but forgot who the company was - the old gear although obsolete is very robust, well made and reliable. I would be looking own this aisle of thought before writing it off as obsolete or trying expensive ways to retrofit what exists with new circuits etc.
Might have been these ..http://www.ec-services.co.uk/circuitbreakers.php
No wholesaler is going to promote a company that may lose them a sale of new gear :)
Obsolete MCCB panel board
atm84,
spadge47,
