As far as I am aware, all these automatic wire strippers are the same.
Bought a SnapOn pair in 2003/4, never use them.
All very nice if all you want to do is strip 2inches of outer sheath, how about stripping longer cables, as in a CU install? not very practical really are they, a waste of hard earned, and I'm a tool tart, wouldn't insult my tool bag with a pair of those,
True.
But I wouldn't have any fingers left I used a knife like the one you showed me.
True.
perfect tool for stripping PVC/PVC you just need a bit of practice, don't use a Stanley type far to sharp
These are fine for flat cable, not so good for round.
Also quite delicate, need to be kept in a case or box.
Prefer the Jokari type strippers.
They look interesting and have some good reviews.
It's a bit of a hybrid design and looks safer to use than an open knife.
So it could work for me.
I just tried it on some 2.5 T&E, it will happily do 8 inches in one go and you can still pull the sheath off easily.
The reason I said 3 inches before is that the more you strip off in one go, the more of a slight mark it leaves on the remaining sheath, so it's better to do more short bites, than one big bite. So if you want a really long strip, only the last one needs to be a short piece.
So, you could strip, say, 24 inches off, sheath pulled off also, in less than 5 seconds.
CK Automatic or Irwin Vise Grip Wire Strippers?
Electrical Tools and Products
midiman,
Pete E,
