Hi Folks, First time post here.....
I'm about to start upgrading my kitchen - and I've got a few bits of wiring to sort. No big issue, but the main thing that needs doing is the backboard for the consumer unit needs changing. Reason being - there used to be an electric storage heating system fitted, with its own meter and CU. This has been removed, however the board is rotten and the old tails are still wired into the fusebox (but checked and and not live!) They are capped/taped up and just sitting behind the hole where the old heating CU was.
The old fusebox at the bottom - I assume to have ONLY the cutout fuse in it, and not an isolator switch?
I Guess the problem here is the tails up to the consumer unit are constant live, and without removing the CU, I'll not be able to change that back board.
Option 1 : Cut the seal on the fuse box and(I assume) cutout fuse, Fit an DP 100a isolator switch, and then go safely about the jobs I need to do.
Option 2 : Contact my energy supplier who will fit an isolator switch for just £60 -however its a 4 week wait, and that will essentially hold my kitchen up for those 4 weeks.
I'm open to any suggestions or advice (other than working it live.....)
you start playing with that my friend. by better order a pine box .
PINE? Cheeky sod, Mahogany for me!
Again, I wasn't intending on pulling the cutout fuse myself! I'm well aware of the dangers thanks.
Part of the issue here is the SP seals - And the 4 week wait for my energy supplier to fit a simple isolation switch. The few sparks I have asked, including the one I intend to move things about, pretty much refuse to touch the SP seals.
Until the Electric company start installing DP isolators I will continue to cut the seals. I'm not working live and to be honest how are they going to prove it ?
Even if i was the last in whos to prove the meter guy crimpped the seal properly in the first place?
It's a good excuse though if I ever want to delay a job for a few month's.
This is the second time in the last few days someone mentions a "isolator required"and getting panicky about seals
Why should fitting a isolator involve anything to do with sealso_O
Thats 2 lucrative jobs that could have come my way in a short time :eek: There must surely be a few bob in this fitting of isolators lark
pulling a modern fuse is not an issue really assuming no load on it, but some of them old ones are a bit iffy at best and even the DNO wont pull them before cutting the supply outside and would rather install a new service head, which says how dangerous they think it is!
If you got one of the really old ceramic and asbestos ones, then i would never even consider touching that for a couple hundred quid job, my life is worth considerably more!
So I've gone with the safe option - My supplier are arranging an install of a isolator before xmas. Slightly better time frame than first though.
Should allow us to change the back plate quickly and safely, and then allow the consumer unit to be changed over should need be.
Thanks for the input folks - Looks like I'll not need the marigolds after all ;-)
scotland
Getting an Isolator fitted - With pics....
jamesd123,
DPG,
