Hi All,
Having recently qualified as an electrician, I am beginning to understand the adhocs and curveballs that customers can throw at you.
Last week I went to quote for a shed installation. The shed is approximately 25m from the property and would be a relatively straight forward notifiable job i.e. SWA buried to a safe depth (500mm), 2 way DB in shed for 1 way lighting and ring final sockets.
Now in my limited experience, as far as I am concerned the install would be directly to the main DB and either protected by a 30mA RCD or alternativly using an RCBO. However the customer has said that they really want the source to be from a fused spur out of the ring final circuit in the garage.
Obviously I am fully aware of the regs and in particular 5.7 of Part P. As far as I am concerned, this is an absolute no go, however I am struggling to find if this is stated anywhere in the wiring regs. Before I say this to the customer please could I have some advice / thoughts.
Much appreciated,
Lee
Far better than taking a feed from the DB would be glanding into a switch fuse. Ultimately this all depends on what the client is willing to pay for.
As Tel has already pointed out, if the customer wants it from the FCU then he is limited to what he can use in his shed.
Ask them what they intend to plug in... They might want a heater and other stuff..
Does the house CU have RCD protection?
Hi Spoon.
The DB is RCD protected. I'll speak to the customer on monday and find out their intended usage and advise accordingly.
If they do go with the 13A FCU option, do you have any advice on the best way to do the testing the installation. It will be the first time that i've fitted a second DB. I'm assuming testing should be at the original DB (specific breaker)?
Many Thanks
Cheshire
Domestic Shed Installation
Domestic Electrician Forum
LGRSol,
Leyland30,
