pirate
Supporter
Good evening all!
I have this job ahead of me, and sadly it's not on a nice clean plasterboard cavity wall, but on a thick-plastered brick wall in a Victorian flat.
Now, I have done some research into this, but quite frankly I would rather have some of you experienced folks point me at the best way to achieve this.
To give you the full picture (did you see what I did there?) the TV will be mounted above a mock fireplace which I have just installed, and which is currently removable, until I have finished everything and have done all the filling etc. Therefore, the vertical distance from the back of the TV to the top of the fireplace is only about 1 foot, or less...below the mantlepiece the cable can exit into the free space behind, and will then be routed to one side, above the skirting, via a drilled hole in the side of the fireplace, a bit of trunking, to the double socket 2 feet away.
The plaster is about 1.5 inches thick. Being honest, would you just raggle it, stick in some trunking, and plaster over?
I know...not best practice, but surely it's obvious there's a cable or two under there? I would label the replastered area. I had to cut the telephone cable when fitting the fireplace, and join it with some new stuff...different colours...put a wee label in the socket for the next guy, and although only 2 wires were in use, I connected 4 for possible future use (Ok, I lied, that was just to help me when I have to do some more work and can't remember what I did!)
Right, buried cables, less than 50mm, but bl**dy obvious...do I protect it?
Any suggestions gratefully received...and brickbats too! The customer is not fussy, but is a VIP!
Good evening all!
Only you could ask this question lol, please tell me your having a laugh.
Thanks Rpa07! I picked up the fireplace from the bargain rail at the big orange shed, then added the mouldings to the uprights and across the main face below the mantlepiece, then drilled and shaped the skirtings to accommodate the hearth. The wall was white, as were the other 3, but the customer insisted on that shade of blue for that wall...(stiffkey, from Crown Decorators Centre-a quarter the price of Farrow&Ball and 10x the pigment!)
Very timely reminder about the location of the socket vs the bracket...thanks for that! Measure twice...my Dad always told me that...and he built boats, so knew what he was talking about:)
obviously you need a socket up there for tv, but for the hdmi leads for smart tv boxes, dvd, laptops etc I have used one of these kits... you put one adaptor on wall behind tv and then run a cat5 to the other adpator in a cupboard or unit containing the media devices. it keeps the tv area nice and tidy when wall mounted. if you can mount the tv far enough off wall without making it look daft you can use a powerline adaptor to feed the hdmi adaptor, it saves running a cat5 in wall. that way all you need up there is a power outlet.
https://www.amazon.co.uk/LogiLink-HDMI-Extender-CAT-5-cable/dp/B0038YXJ1W
meant to add you could also do usb over cat5 to allow for usb media devices in the cabinet to left of fire place.
Oh MDJ...no, I really am asking! Hoped someone would give me some tips...I have done a few of these, but it's amazing how asking sometimes gives you answers you hadn't thought of...and Rpa07 just reminded me of a basic point I might well have overlooked. I am old, you see...and have learned to keep asking and keep learning...
and it's "you're", btw!
Plus, I am going to secrete a Treasure Map in the cavity! All you need to know is the address!
Thanks Gavin JH, good thinking there...I use powerline adaptors quite a lot for broadband but hadn't thought it through this far.
I can mount TV with enough wall-offset, plus there is a cupboard very close as seen in picture. I think customer has Humax freesat and NowTV boxes, so HDMI cables. The TV has a detachable power lead, moulded 13A plug to cloverleaf.
Dave OCD, thanks for that, I wondered if 50x25 might do the trick. So glad I asked this, so many suggestions! and to think I might have just gone ahead with a raggle and a bit of galvanised strap buried in there!
Yeah I'm with Dave with the Trunking.
I think in this situation I would stick a dual item box (Brush plate and single socket) where the TV is to be mounted ( probably slightly offset like Rpa07 mentioned because of the bracket)
Then id chase 2 x bits of 50x25mm trunking (or 1 trunking 1 oval) down vertically to a twin box directly bellow but the same hight as the existing sockets which i would put a blank plate on then chase 2x bits of trunking to vertically to another dual item box next to your exiting socket (Switched f spur/ brush plate)
In the Trunking put 2x hdmi 1 x cat5e 2x coax) use the other trunking or oval for the power.
If you need to ever get more cables up just pull out the mock fire place and your be able to remove the blank and pull both ways.
If you have a flat to wall bracket the switch spur below allows you to easily isolate the TV.
Maybe a bit of overkill but might save you time in the long run.
well all
hdmi then, so can use the power over ethernet system i sent link for to avoid having devices in plain sight. you can run another cat5 to behind tv for future upgrades and smart tvs etc...
pirate
Supporter
Glasgow
Wall-mounting a TV in the best way
pirate,
Mike Johnson,
