1mm or 1.5mm T&E for standard lighting circuit in your average house.
1mm or 1.5mm
  • 1mm T&E
    Votes: 58 61.1%
  • 1.5mm T&E
    Votes: 37 38.9%
  • Total voters
    95
You couldn't totally assume 1.0 is ok in all circumstances you could invent. Never mind volt drop for now, but if there are 20 circuits bunched in 50c ambient under insulation you'd have to do a bit of redesign.
This kind of statement never makes sense to me, the average domestic lighting circuit is put on a 6A mcb with cable size calculated accordingly.
10-15 years ago everyone suddenly started wanting loads of GU10 down lights in each room. Even though 4 would be ample, customers wanted 6,9,12 down lights in each room. This was when you would use a 50W or 35W GU10. Added to that the wall lights the loading soon added up. As I said in my post when people started using LED the loading dropped dramatically.
Leesparkykent,
satori,
