1mm or 1.5mm T&E for standard lighting circuit in your average house.
1mm or 1.5mm
  • 1mm T&E
    Votes: 58 61.1%
  • 1.5mm T&E
    Votes: 37 38.9%
  • Total voters
    95
I thought I'd explained that in the previous paragraph - it's so the end user can't change a 7w light bulb for a 100w light bulb, thereby potentially messing up calculations or burning something next to it or whatever. In certain situations the tenants take the light bulbs out and steal them, so there's an argument there as well.
You never heard of diversity?
But there's no rhyme or reason for your concerns.
1mm smothered with insulation, #6 with 6A ocpd, will be fine. With a 1.5mm, that could be 10A, what ocpd could you use, that would improve on 1mm?
An RFC could easily be overload, once you step out of the house. Wire RFC in 4mm?
1mm & 1.5mm have the same size cpc.
So that just leaves your nuetral?
I do agree to an extent but I still just prefer to install 1.5mm2 just makes me feel better?:tearsofjoy: Think its all down to my journeyman instilling in me that 1.0mm was the devils cable:laughing: and starting out my career in mostly commercial buildings that usually the minimum csa was 2.5 for lights and boy were they a bugger to install in a tamlite emergency bulkhead with the wee PCB terminals. I know there aint really no rhyme or reason I just wouldn't consider 1.0mm and always default to 1.5 unless the calcs specify bigger....
I remember years ago getting called out to a building where all the lights weren't working, a day after they'd been re-lamped, some jakey had stolen all of the starters from the sides of the fittings:dizzy:
Out of interest what's most commonly used?
Pretty suprised you asked to be honest, surely it depends on what your connecting to the circuit? PS, 1.5mm2, well maybe 1.0mm2, or even 2.5mm2, hmm, where shall I start?
I'm on about a standard lighting circuit, in your standard house. For example if you was pricing/1st fixing a traditional built newbuild 2 bed semi with standard pendants...what would your usual go to cable be for the lighting circuits? Mine would be 1mm T&E others would choose 1.5mm T&E. I was interested in what is most commonly used, hence the poll.
Go for 1mm2 if your doing a couple of new builds then the cost saving will soon add up (I know its a complete contradiction to what I said earlier but your not me so I assume you don't have the same reservations about 1.0mm that I do)
There's a lot of mention of the reduced load of modern LED lighting but no mention of the sometimes appalling power factor and large inrush currents of many of the LED drivers and fittings that at least partially offsets that......
True, but thinner cable will keep the inrush current down a bit. ;)
When rewiring pulling through conduit switch drops etc, 1mm always,an if the circuit needed to be split into 2 circuits say per floor so be it. Never had to do this personally on bog standard 3 beds.
Leesparkykent,
satori,
