Pete999
Worked fo a Large West Country Building and Civil Engineering Firm for a while.
The Guy who was the electrical Manager was a tight fisted so and so, he would not supply us qith cable clips, we had to use cable off cuts and plaster board nail to make our own, they won't be seen so whats the problem was his answer.
Fitting Ceiling Roses and Batten Holders, he had another trick, he supplied us with 1 1/2 no6 screws for this task, the only stipulation was use 1 and push a plaster board nail on the other side, so each ceiling fitting had 1 screw and 1 nail as fixings, why did you put up with that? you may well ask. Whilst I don't condone this type of thing, when you had a new Wife and Baby as well as a Mortgage you did as you were told, I lasted about 9 months, anyone else got any horrors, or are the frightened to say? there is no statute of limitation mind you.
Thats outrages Pete. That made up cable clip isn't A3 compliant, just use nails.
Ha ha, I do very little domestic work, but I have seen this a couple of times and it always made me chuckle.
What didn't make me chuckle was coming across old switchgear that was held up with a bloody 6" flathead rusty screw, I hope that wasn't you @Pete999 :)
Only an old bakelite Wind up Megger, bell wire as the test leads, wonderful eh?
I am not alone! Pete, that is what I experienced for years! I remember the megger getting harder to wind if there was a problem....it meant the circuit was 'down'.
I eventually went and did my 2391 and passed it because I was obsessed with passing it. That was about 8 years ago and I am now back to square one, I have forgotten stuff. But I am back now and am going to re-learn. Exciting times.
I experienced my boss sleeving up a cpc in a piece of twin and earth to make a two way circuit an easier option with less chopping out of walls. Now that is a class act of 1980's disregard of the 15th Edition.
It gets worse as well.
To be continued.....
Cut clasp nails to fix back boxes :)
Hi. I know this happened all the time on new builds when I was working. It was easy to hammer a cut nail into the soft blocks and it was quick.
If the cut nail was sharp I can see where the problem lies, but mostly they are rounded.
The main problem I can see is if the back box is needed to be removed in the future, a boxed which is rawl-plugged and screwed is easier to remove. But, if the box is plastered into the wall then a mess will be required to remove either fixing method.
Or am I missing something?
This isnt a pop, I am keen to learn.
Regards
Sym.
Thanks telectrix, I know nothing about such a tool.
I have made a real mess in the past trying to remove back boxes, mostly trying to change a single socket into a double sockeck (I ended up learning that a double surface Patrice attached to the single metal box caused less mess). I will look into this.
Cheers
Sym
Cheers
Sym
Fein Multi Tool FMM350QSL Quickstart Starlock With 17 Accessories 110v 72295262241 - Fein from Alan Wadkins Ltd Toolstore UK - https://www.alanwadkinstoolstore.co.uk/power-tools-c17/multimasters-multi-tools-c174/multi-tool-fmm350qsl-quickstart-starlock-with-17-accessories-110v-72295262241-p35202/s38292?gclid=CjwKCAjwur7YBRA_EiwASXqIHK74TBJPkg8IGaCEAlPBkCCQbnFzP29RauxPpZdj5B7Qb9CFZi5_WBoC7PQQAvD_BwE
Regards
Sym.
Might of been easy back then, but its a right pain in the bum to get them out now, back boxes with cut clasp nail that is :D
Hardly Mate I only did 9 months of it all on one site, an interesting time.
Didn't do any work in Cambs did you??? :D
Oh that's naughty
Srtima...I will give you a thumbs up for the giggle. BTW I have never worked in Cambs as a sparks. Nice to meet you.
Thanks for the link telectrix.
One thing I will say about the use of cut nails with mounting back boxes is I doubt they all were at exactly at the same level from the floor.
If it was my house then sockets at different levels would hurt my eyes.
Pete999
Northampton
Retired Electrician
Business Name
None
Bad practices in 1970s House Bashing.
Pete999,
Adam W,
