Whats your preferred method and therefore tool of choice for chasing all types of hard walks (brick, block, stone etc)?
Is it the grinder and hammer drill method (if so do you use a purpose demo hammer drill or a standard SDS rotary with hammer function). battery or corded grinder?
Is it a wall chaser and hammer drill or demo drill.
Is it good old hammer and chisel.
Or any other methods?
Obviously you guys do not come accross beach pebble or Marland brick, both very common around here. Both require diamond cutting disks and then grinding disks. Beach pebbles can deflect a drill bit when drilling through a wall causing it to jam,have had to cut a few off and leave them in the wall
Nope, never had to work with cob or bungaroosh either.
I use diamond discs anyway, which cuts through anything I've come across - plaster, brick, block, concrete, water pipes...
Swansea
Chasing walls.....weapon of choice.
Scott Jacob,
Electric Magic,
