you are being watched .just watched that buzz. sure i saw you in there
I am 100% it is not condensation but thanks for the suggestion I think it has something to do with the metering as it had earth fly leads also although the new panel MCCB board main switch is off the N-E PME connection is made in the cutout.Did you try drying the exposed surface of the insulation between the bared ends of the cores and the gland? 10MΩ could just about be caused by condensation.
I think 'vgi' should read Vigi, Schneider's trade mark for their residual current add-on actuator.
The end was mad off into the individual cores ready to go in the schools old Square D board where the existing is.I would go with damp in the cable.
Especially if it’s and of reel.
but the OP question has already been answered, so .......Thanks, Pete and Tel There are other parts of the forum its like you have both hijacked the post to talk about something else some people are trying to give a constructive reason. I am all for having a bit of banter but every time I post a thread up on the forum it gets deliberately taken off topic or daft photos.
Not true Ant I gave you a perfectly good test procedure, and I don't think anyone has high jacked your post. Least of all me and all the others, just a bit of fun on a Sat morning.Thanks, Pete and Tel There are other parts of the forum its like you have both hijacked the post to talk about something else some people are trying to give a constructive reason. I am all for having a bit of banter but every time I post a thread up on the forum it gets deliberately taken off topic or daft photos.
It was only a quick test and did R1 + R2 could not work out why but my gut feeling is the PME and metering. I hope we don't have to fit a lot of these PITA as you have to wire everything for the metering and that even by Schneiders own Tech dept.I knew Anthony would SHOUT at some point - that was true Hijacking!
I agree with Pete and complete disconnection for true reading otherwise you’ll be wasting precious time.
It kinda was hijacked by you SciFi weirdos but true, he did have a couple of ideas given. Kirk OUT!Not true Ant I gave you a perfectly good test procedure, and I don't think anyone has high jacked your post.
So what was the reason Tel?but the OP question has already been answered, so .......
