View the thread, titled "Are 30mA split load consumer units non compliant under 18th edition" which is posted in UK Electrical Forum on Electricians Forums.
Hi All,
Just wanted to see what peoples opinion is
is installing a 30ma Split load board compliant/ non compliant under the 18th Edition or you have to use RCBO's for each final circuit?
BS7671:2018, Page 155 regulation 531.3.5.2 is a note which says on TN systems which states " Exept where particular restrictions on selectivity applies; Several circuits may be protected by the same device"
Views?
They are still compliant, and the disruption to end user is minimised if half the house goes off is initial design.
Upstairs lights with downstairs socket....
Cooker on different rcd to kitchen sockets
It would be simpler for us just to say it has to be all rcbo now to comply, but mr customer can find split boards in his local diy.com retailer
Commonly installed but the regs do state that the failure of one circuit shouldn't effect another circuit.
Similar situation with SY cable. It's not a BS7671 recognised cable but widely used.
More to do with one circuit breaker protecting one circuit disconnecting will not effect another , as the regulations allow more than one circuit to be collectively protected by one rcd.
Reply to the thread, titled "Are 30mA split load consumer units non compliant under 18th edition" which is posted in UK Electrical Forum on Electricians Forums.
LOndon
stefanli69,
gazdkw82,
