The new kewtech kt63 + I think it is looks pretty damn good... Has built in dc testing for rcds which is good as we are moving towards type a etc.... Most can't test them... Only the ac side... Its nearly £1k though
I have a Megger MFT 1741-BS. Had a Megger MFT 1553 before that. (Still have it as a backup.) New one is much faster and also has rechargeable batteries. Great instrument, although some would still swear by the 1500 series over the 1700 series.
Speak to Megger and get it upgraded to the new 1741+ I think they will do it for a low price....
Do they offer a deal on upgrading to the 1741+?
I'll be honest - I was fuming when I found out that it had been released as I've only had my 1741 just over a year and would have bought the 1741+ had it existed at the time. (I see there's a nice limited edition black version of it too...)
A couple of Megger 1553s one with Bluetooth feature that was used once.
interested to hear that Megger potentially do an subsidised upgrade to the 1700 series. Does anyone have any idea how to go about it.
Recently got a DiLOG DL9118 MFT as it seemed to be a decent enough unit for the price, but don't have any experience to compare that with, say, the Megger MFTs.
However I still prefer my Megger MIT230 for general bond impedance testing (seems a little quicker / more responsive) but mostly because on insulation it goes up to 1G ohm which I have found useful (not domestic testing).
Does anyone else test their MFT against a Cal-Card and a known RCD? Mine gets a run through and spreadsheet log roughly every month. Give me a heads up as to potential issues.
What a great idea!
I have never seen the CalCard before, but I have some other resistor calibration boxes that are not as convenient to carry/keep with the instrument/etc.
Are we the only country to use MF testers ?
I have spoken to sparks from America , Canada , New Zealand , Australia , Greece and Spain non of which use a MF back home
Yes, they don't get used much here in Australia, most sparkys use a multimeter, and have an IR tester and an RCD tester.
I actually purchased a used Di-Log 9083P which is built in the same carcass as a Seaward PAT tester. But I had to purchase that in UK and have it transported to the colonies.
I quite enjoy using it, having so much to choose from on one unit.
We don't have the same procedures as you have in 17th, or I think it's the 18th now!
That is interesting to hear. Certainly by time you have bought an insulation tester and a RCD tester you might as well buy a MFT!
However, most multimeters cover a wider range of measurements than the equivalent MFT capabilities, but generally not as capable at the very low (bonding) or very high (insulation testing) resistance ranges.
bought my 1553 2nd hand in 2013 from MDJ.. it's now 12 years old and passed every calibration.
I have a Megger made in the 1960s. I have had use of it since 1993. I still use it when I don't need a calibrated result. It has a DC generator 500 & 1000VDC. The meter has a current winding and a voltage winding. The result of the two magnetic fields moves the meter hand; effectively an electromagnetic ohms calculator. Just beautiful.
I've just done the same, had my trusty Mft1552 since late 2006 and is still passing calibration and never missed a beat.
Just bought the 1741+ and it's every bit as reliable and am very pleased with it. A worthy investment, hopefully it will last as well as the 1552!
Sy
After using a wind-up megger for many a year and borrowing from others. Thought I would embrace modern technology and purchased the DiLog DL9110 just over a year ago.
Does everything I need for the occasional domestic work that I do, it's not the quickest when carrying out no-trip tests, but happy with it and its 'relatively' cheap. No issues with it so far, just wish I had paid a little bit more for the next model up that comes with remote test probe.
Dan
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Multifunctional Testers - Which one have you got and how long has it lasted?
Electrical Tools and Products
Dan,
Lister1987,
