After using a wind-up megger for many a year and borrowing from others. Thought I would embrace modern technology and purchased the DiLog DL9110 just over a year ago.
Does everything I need for the occasional domestic work that I do, it's not the quickest when carrying out no-trip tests, but happy with it and its 'relatively' cheap. No issues with it so far, just wish I had paid a little bit more for the next model up that comes with remote test probe.
DiLog state that their remote test probe (TLRP911x) can be used with the DL9110. About £40 to buy separately.
Kewtech KT64 V1 6yrs and counting use it for spare internal solder to lead sockets re-soldered.
Kewtech KT64 V2 7yrs + still going strong (above issue not apparent due to redesign) They are solid & reliable
Just wondering which multifunctional testers you guys have, and how long have they lasted?
Hoping this becomes a handy thread for you all. There seems to be a massive price difference between them all. But then I guess some do things others don't? Not sure. :)
Let us know which multifunctional testers you have, which ones you wish you had, and how long the one you have has lasted so far. :D
1994 Meggers, Robin DVMs and clip-on same age, Fluke multi ditto, Hewlett Packard AC/DC clip-on that drew graphs even back then, Clare tester and a lot more even older. All employer provided but donated to me on retirement. Not used seriously now of course!
Robin 3 piece tester set , got it when I finisged my apprenticeship
still going strong ? after 20 years
I bought a second hand metrel Eurotester several years ago and it has worked without a problem all these years, but it is now looking abit scruffy.
My 1552 has died after ten years, long live the Megger... ?
I just purchased the Kewtech KT63 which arrived yesterday. Did a quick RCD test and one side of the cu is fine, the other side failed so needs a new RCD.
This is fastly becoming an expensive hobby!
I have my late brother's ROBIN kts 1620 MFT he had from new used it while working for London transport so it has sentimentle value to me and I would love to put it to good use
My Dilog DL9118 died in the middle of an EICR on Friday.
Shows a continuity reading of 0.24 on low ohms even with test leads disconected.
Lasted around 2years :(
Had to pop to CEF ended up getting the Megger 1941+ with the new EV adapter. Didn't really want to pay that much. Fingers crossed it lasts.
Bummer.
I hope mine lasts longer, though to be fair it hardly gets much use compared to a professional electrician. If/when it goes I was thinking of the Megger, not really for EV adaptor or anything like that but to have the earth rod testing via two spikes.
I have my old faithful Megger 1553, but it doesn't do Type A or B RCD tests.
I'm picking up my Megger 1741+ tomorrow.
I thought about getting the EV adaptor as it would be £120 cheaper to buy it at the same time, but decided to wait until I actually need it.
The reason I think I will need the EV adaptor eventually is that I do a lot of EICRs, and it's just a matter of time before I come across an EV charge point that will need testing as part of the EICR.
It could be argued I suppose that for an EICR you only test up to the point of connection to the fixed wiring, but in view of the potential danger of a malfunctioning or incorrectly installed EV charger, I personally would prefer to be able to give it a thorough test.
Also, an EV charger would not be picked up by a normal 'PAT test', and I doubt any 'PAT' person would have the equipment or knowledge to test one.
Damn I knew should have bought the damn thing! ?
Dan
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
United Kingdom
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Multifunctional Testers - Which one have you got and how long has it lasted?
Electrical Tools and Products
Dan,
Lister1987,
TrueNAS JBOD Storage Server
