Guest viewing is limited
Does anyone know if the Memera 2000AD fuse box is now obsolete . MY EICR report says there is no RCD protection to 3 circuits so I need to replace it as it is obsolete . .
If have to replace this can some recommend a suitable one please which I can pick up from a local DIY place
Do these have to be metal clad and what what does SPD mean
Image of the one I have attached
Unless used where the upstream fuse is 60A (Most supplies are 80A or 100A), this can't even be fitted to meet the current regs as shown.
ok thank you...just saw it on the website . The electrician mentioned he will be installing one with 3 RCD's from fuse box if he were to change it .
Fusebox = very decent brand. Nothing wrong with dual-RCD board.
Consider paying extra for an all RCBO board, worth it in long run so faults are limited to one circuit.
west midlands
Other
If other, please explain
Member
Fuse box memera 2000 AD
ssn1122,
ssn1122,
