Guest viewing limit reached
Darkwood
Callout yesterday to lights flickering and arcing sound in lounge light due to loose connections. Sorted that and wanted to do some tests/checks before I left, found this. Meter, cutout and 2 way(!) consumer unit for the house all mounted in a low level lounge cupboard. I only really found this as I had to move the customers stuff out of the cupboard to get at the CU. Wasn't about to leave that as it was so accessible and there were children in the house so I removed it and left an electrical danger notice explaining to the customer the urgent need to upgrade the earthing, bonding and RCD protection, and to have a full EICR carried out. Took a load of loop readings from the 2 circuits, highest was 0.41 ohms so I wasn't too bothered with the lack or RCD protection. Probably should have phoned EDF and kicked up an absolute stink but I didn't have time for that and 2014 was a long time ago. The sticker on the meter cover wasn't broken but the name information had been ripped off and the crimp seal was blank, presumably the meter fitter hiding their tracks. Perhaps regular EICRs should be encouraged more for non-rented properties.
8K
Darkwood,
vjsmarwick,
