Can you give a drawing for that?
All feed wires are permanent lives it's only the switch wire that is dead when the light is turned off.
Normally on say, pendants or battens, the perm live will go to each light on the run and then an individual switch wire goes from the rose to each switch from each fitting. Can't picture the way you're saying.
