electricl certificate
a customer has asked me to change their fuse board which i did.
Replacing a Consumer Unit is notifiable under Part P
If you did replace the fuse board you should either be already registered to do so under Part P, or you should have informed the local aurthority BEFORE starting this work.
Quote
"i am fully competent to test and have plenty of experience in the electrical game"
Hmmmm I guess your customer is now uninsured in the event of an electrical fire....Nice one!
I believe I have found a new home for 'Old Rubber'
I think we established this 3 days ago, it's always best to read through a thread before posting.
ive sent off my application with my cheque for 500 squid and once i am part - pee registered i will issue eic cert to customer...problem solved!!
then i will go round issueing periodics to all my sparky mates who cant issue there own certs...
the whole system is a joke
Shows how little you do actually know. Good luck.
egginyourface,
Spudnik,
