I think the question to ask is "why can't you get the right tool near the locknut", is it because your drilled the holes too close together, or the enclosure is too small, or as I said in a previous post I can't believe that a manufacturer would put an enclosure on the market with knockouts without thinking this through, or is everyone going to blame a previous muppet. 😇
my local housing association has flats, making a fortune from rent and leasehold charges. fleet of new Transits every 2 years. and you should see the bodged repairs. broken timber purlin repaired with a couple of coachbolts. no support. disabled ramp that nobody can use. ( this eventually was demolished following a water supplly leak they'd built it over.) almost on a par with the council taking 14 weeks to fill a pothole after it was reported dangerous and several cars damaged.
warrington
Retired Electrician
Tightening locknuts with hammer and screwdriver-dog rough or not?
Electrical Engineering Chat
briwire,
Moley,
