Is 4mm heat resistant cable okay for 7.5kw range cooker?
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind the cooker. He put this size in as I didn't know what size cooker I was going to be getting.
I ended up getting a 7.4kw range cooker and the electrician has connected it with 4mm heat resistant cable instead from the cooker to the back plate, instead of 6mm. Is this okay, and is it okay with the 10mm cable and 32a fuse?
At least he used heat-resistant cable, most just use twin and earth.
I'm yet to see T&E showing signs of deterioration behind an oven, but it's not the ideal cable for pushing back behind an appliance. Flex is inclined to drop easily behind a kitchen unit and naturally forms itself into position.
Loop of string around the cable, down the back to the space underneath and out the vent that should have been cut in the top of the kickboard. Gently pull on the string as you push the oven back into place.
chris140,
chris140,
