View the thread, titled "Wiring to control 2 lights independently with a dual light switch" which is posted in DIY Electrical Advice on Electricians Forums.
Hello,
I am trying to understand the wiring done for an already working setup in my home by an electrician: a dual light switch (Legrand branded, if it matters) with only 2 wires connected to the switch. It really puzzles me how the switch can control two separate light fixtures, since there should have been 3 wires instead of just 2 connected to the switch? Can someone please explain? Thanks in advance!
lets see a photo
That doesn’t sound right.
Minimum, you need a supply in, plus a switchwire out to each light.
I don’t know how the wiring is done in Mauritius, but in Uk, we have combined cables containing a number of separate cores inside…
So maybe he means 2 cables, not 2 wires?
It could be a slave switch where you would have a L in and a common wire out to a master switch.
Reply to the thread, titled "Wiring to control 2 lights independently with a dual light switch" which is posted in DIY Electrical Advice on Electricians Forums.
