Guest viewing is limited
View the thread, titled "Spur/Junction for outdoor socket for PHEV charging?" which is posted in DIY Electrical Advice on Electricians Forums.
The landlord should have had this done by now it is a legal requirement. I personally would not be touching anything until this is done. Can you show a picture of your consumer unit?
Unless there is an rcd before that board ( looks like the main switch but has a little test button on it)
It is unlikely to be suitable for the addition of an outside socket.
I fitted several of these GE boards back in the day. That's not a test button, it's an embossed section on the aluminium profile used to link the two SP switches that make up the main switch.
No RCDs in the house but there are two sockets outside on the rear conservatory that have RCD protection, assuming they’re safe to use?
Was describing what an rcd looks like, NOT suggesting that the board had one!
Another question then, would 6A overnight for 7 hours be safe from a normal plug? Similar wattage to a 1500W heater and they can be plugged in for a fair amount of time
You have no sockets that are suitable for supplying anything outdoors. This includes the sockets inside the house.
Sorry, yes they should be ok.
Reply to the thread, titled "Spur/Junction for outdoor socket for PHEV charging?" which is posted in DIY Electrical Advice on Electricians Forums.
