Colin33
Hi all, I'm not so familiar with pvc conduit having used it very little in the past. However, I have a small workshop/man-cave to wire, it is attached to a small domestic dwelling. I need to wire this part using 20mm conduit.
I have a few questions:
1: Am I right in thinking I can wire multiple circuits together in the same conduit? (ie socket outlets and lighting)
2: Can I use a single cpc for all of these circuits or is it best practice to run separate?
3: If conduit is connected in and out of a socket outlet back-box, can other circuit conductors (ie for lighting) run through that back-box?
Is there a CU going in the garage ?
What earthing arrangement ?
Can you give some more info on the intended layout ?
Supply cable, rcd etc ?
I assume you're going to use single cables and not T&E.
Yes, supply via buried SWA from the main dwelling into new CU. The main house is TT. New CU to have RCBO on all circuits. The workshop area will have a lighting circuit, and two radial socket circuits in pvc conduit. The separate 'living area' in this building will have lighting circuit, water heating, and a ring final, a tiny bit of UFH and all in twin/earth buried in the studwork.
Colin33
Cornwall
PVC conduit question
Domestic Electrician Forum
Colin33,
Colin33,
