View the thread, titled "Reflections on Transitioning from Plumbing to Electrical Work" which is posted in UK Electrical Forum on Electricians Forums.
One is a Pipe and one is a connector.
Push fit connectors
Also known as push-to-connect or push-in fittings, these are installed without tools and lock pipes together using pressure from the plumbing system. They can be made from a variety of materials, including brass, copper, plastic, and DZR brass.
Push fit pipes
These pipes are typically made from durable materials like PVC or ABS, which are resistant to chemicals and corrosion. Push fit pipes can be used with push fit connectors to lock pipes together, even if the pipes are made from different materials.
I actually meant that plumbers use push fit connections for pipes.... and electricians use push fit connections for wires.
The similarities of making both trades less and less technical.
After working as a plumber and gas engineer for nearly 12 years, I decided two years ago to retrain as an electrician. It’s been a challenging but rewarding journey, and I’m on track to be fully qualified by May/June 2025. Along the way, I’ve come to really appreciate the differences between the two trades and the level of professionalism within the electrical industry.
One thing that’s stood out to me since I started working alongside electricians is how much more organized they are compared to plumbers. Whether it’s stock management, diary planning, or van organisation, electricians, on average, seem to operate on a whole different level.
I’ve spent a long time wondering why this might be, but as I’ve started taking on minor works myself, I think I’ve figured it out. The electrical trade is so competitive—if you miss a call or don’t respond quickly enough, there’s a good chance another spark will step in and get the job. On the other hand, plumbers in my area can go months without answering their phone and still be in demand.
It’s this constant need to stay ahead of the game that seems to drive electricians to be so efficient and well-prepared. It’s something I’ve come to respect massively and something I’m working hard to adopt as I make the switch to this new and exciting career.
I would love to hear any other thoughts on the matter?
Out of interest, what is it that attracts you to electrical work over plumbing?
Reply to the thread, titled "Reflections on Transitioning from Plumbing to Electrical Work" which is posted in UK Electrical Forum on Electricians Forums.
